Suspension hints and tips?
Mr OCD
1,974
Manchester, UK
Ok ... so it is now time to replace the original suspension on the LC. I've got a basic idea of what needs doing and I'm expecting some fun and games to remove the old stuff given the car is now 10 years old!
So what hints and tips do you have?
(sending it to a garage is not an option :p)
Klone
1,514
Clacton On Sea
depends on the method in which you're going to fit mate.
i would suggest soaking any bolts you will be undoing overnight in WD40 or something, as some are a sod to undo!
my biggest suggestion is if you are going to be running coilovers make sure you grease the threads when you do the adjusters back up. im about to buy new coilovers as mine has seized because the garage didnt grease them! last time i go there!
Mr OCD
1,974
Manchester, UK
I was going to do the back first... as easier ... but my mate reckons if I can't get the fronts out I'm going to be a bit pissed :)
It's a shocks / springs kit so no worries about coilovers seizing! :)
Klone
1,514
Clacton On Sea
I would go with the fronts first for that reason lol
also, might as well replace the top mounts whilst your at it, i didnt because they looked ok, now they are knocking too.
pissing low cars! :cartman:
Mr OCD
1,974
Manchester, UK
:rofl:
New top mounts / bearings on the workbench waiting... ;)
Not looking forward to doing the fronts... especially getting them out. Apparently access can be tight on the drivers side front?
csd_19
2,280
28
Angus / Edinburgh
Like Tom says, give it a good soaking in penetrating oil - I tend to wire brush the front struts around where they slide into the hub and then soak em, same with the bolt/nut of the strut clamp. Also soak the ARB link top nut/bolt. To help persuade the strut clamp to open, you can get a spreader tool or make one your self with a 7mm allen key, grind down to make an oval. This fits in the back of the strut clamp and eases it open.
Deffo replace the top mounts and bearings, for the extra money and ten mins it'll take it's a no brainer.
IIRC the rear damper lower fixing nut should be replaced, its a self locker.
Depending on the condition of the bolts you might want to replace the ones you remove - OCD and all that ;)
Better to have a pain of a time doing the fronts first, you'll love the rears for the simplicity and speed! :D
csd_19
2,280
28
Angus / Edinburgh
Yep drivers one can be a bit tight as the longer driveshaft hits the subframe when you push the hub down to release the strut.
Mr OCD
1,974
Manchester, UK
Will do all that ... :)
I have new mounts / bearings... and errrr ... new bolts as well... :whistle:
Mr OCD
1,974
Manchester, UK
Is it possible or do I need to unbolt anything else? - I may do the drivers side first and see how much fun I can have ...
For the splitter won't a chistle do it? :confused:- although obviously I need to keep the hub split whilst I pull the strut out ... I do have a grinder and plenty of allen keys though.
csd_19
2,280
28
Angus / Edinburgh
*I take no responsibility for personal injury or damage to property as a result of the following post*
It is possible if you have a set of spring compressors handy ;)
Take the wheel off and then jack up the hub so you are compressing the spring while still on the car. Once it gets to the point of almost moving the car off the axle stand attach the spring compressors to the now-shorter spring. It's a faff but you can get them in there. Making sure they are on tight slowly lower the hub. This will give you room to pull/wiggle the strut out of the hub.
The other way would be to unbolt the driveshaft retaining nut and remove the driveshaft from the hub, although I can't remember if you get enough in-out movement on the cv joints to push the end of the shaft back through the hub and clear of it. OR undo the 6 bolts holding the driveshaft to the gearbox flange, remove the driveshaft nut and remove the shaft altogether... :)
Reactions: Mr OCD
csd_19
2,280
28
Angus / Edinburgh
You can do yep - changed out a pair of top mounts and bearings before doing it that way ;)
But you do have to put use them "upside-down" so the threaded portion sticks down the way. The set I had had a Phillips-style cross in the end of the threads so I could tighten them with a big screwdriver lol :D
Mr OCD
1,974
Manchester, UK
Excellent... have some rep :D
I will do driver side that way ... no need on passenger side I hope! :rofl:
Mr OCD
1,974
Manchester, UK
Will be starting the job tomorrow night ... tonight wheels off, wire brush and WD40! (After I've put the engine back together!)
csd_19
2,280
28
Angus / Edinburgh
Anywhere near you sell Plusgas, like a local tool store etc? Waaay better than WD for freeing stuck bolts etc ;)
It's only the driver's side that a b!tch lol, the rears are almost comically simple!
Mr OCD
1,974
Manchester, UK
Always struggle to find PlusGas!
:rolleyes:
Halford sell it?
Yeah I will save the easiest for last ...
Mr OCD
1,974
Manchester, UK
Made a start... Wheels off, everything cleaned down with wire brush and loads of penetrant spray...
Got the pinch bolts out (good job have new ones) ... And started on driver side.... The shock has come out about two inches from hub quite easily... It won't come out any further... Suspect that's because it's time to use the spring compressors... That's for tomz.
Also knocked up my own hub spreader tool from 7mm Allen key... Perfect :)
