ETKA info - cluster 1P0920 941C
skard
397
UK
Everyone has a conv module, just depends on spec of it.
The large mfd can just show larger trip info until you upgrade other bits, well worth it just for large screen
jamiegwillym
105
S Wales
Well the cable arrived today. Had a bit of difficulty with the drivers as the CD that comes with the cable doesn't allow them to work on windows 7 however after a bit of digging I worked out how to do it and I've managed to get the SKC from my current cluster! :D Just need to check the replacement cluster now.
What did you have to do to get it working on windows 7?
robthebubble
LED & Headlight Master
Feb 22, 2011
1,442
Solihull, West Midlands
Rob,
Out of curiosity did you pick this up from of the well known auction site a few weeks ago? I was watching one located in Brum, but I left it in the end as I was unsure of how hard it was to swap the cluster. I'm curious to see how hard it is doing, as I really miss the large mfd from my fr.
Rich
Yes Rich, but I ordered it from a selled based in the US as if there was any issues I could go through a dispute and get answers in English. Took a week to arrive and has worked fine so far.
I followed a guide from my VAG COM cable and also a guide on youtube. It told me where to download a driver to make the cable work. Seemed to do the trick just fine and an easy process too...can send you the info if you want?
skard
397
UK
How may versions are there? I rememeber seeing about 4 in etka
There's loads, tens of them.
I have to admit I'm not sure how the part numbering worsk on SEAT but I know the VW ones changed early '06 - now some have to be compatible with door modules due to the LIN protocol which earlier models didn't use, so it isn't always a caser that a newer one is better.
As all Leon's are 5 door, then don't buy one that came factory fitted into a 3 door VW.
Best way to see what one you want is get someone with the spec you want and ask them to relay the part number - I have 1K0 959 433 BT in both the Golf and Altea (coincidentally) and have rain-closing, coming home lights etc. Stuff that I don't use as I have VCDS but it's nice to have a menu :happy:
b21playa
oil burner
Jan 10, 2005
544
Birmingham
robthebubble
Feb 22, 2011
1,442
What problems did you encounter and did you get it sorted in the end?
I've just seen a v5.5 http://www.resettools.com/vag_can_commander_5.5_with_pinreader_3.9_beta
Thing is it doesnt mention mk1 leon, which I could do with as well
Well I was swapping over the whole cluster so that's were I struggled...went to Midlands VW who did it all for me of £50 but they confirmed that the Pin code I got was the same as the one they obtained.
As for using it on an MK1...no idea to be honest.
b21playa
oil burner
Jan 10, 2005
544
Birmingham
cool
Ive ordered the cable so will see how it goes.
In the mean time, Ive programed the remote on the mk2 for central locking, and order the key blades from keysinthepost.com
joostdeblok
189
Netherlands
Can anyone confirm VAG Commander 1.4 connects to the older style instrument clusters up until 2009, i.e. the pre-facelift clusters? Only needed for extracing SKC and correcting mileage.
Works for all MK5 Golfs with the old immo4 system as far as i know, only need to know which system the Leon/Altea/Toledo used until 2009.
Thanks in advance.
robthebubble
Feb 22, 2011
1,442
It should do...it connects in the same location as all the other cables, I.e. just below the steering wheel (RHD cars...not sure if LHD cars are the same?)
It's the software you need to make sure works and it worked fine for me when I set it up.
