Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Well the cable arrived today. Had a bit of difficulty with the drivers as the CD that comes with the cable doesn't allow them to work on windows 7 however after a bit of digging I worked out how to do it and I've managed to get the SKC from my current cluster!Just need to check the replacement cluster now.
Everyone has a conv module, just depends on spec of it.
The large mfd can just show larger trip info until you upgrade other bits, well worth it just for large screen
Rob,
Out of curiosity did you pick this up from of the well known auction site a few weeks ago? I was watching one located in Brum, but I left it in the end as I was unsure of how hard it was to swap the cluster. I'm curious to see how hard it is doing, as I really miss the large mfd from my fr.
Rich
What did you have to do to get it working on windows 7?
How may versions are there? I rememeber seeing about 4 in etka
Can anyone provide a link to the cable required to extract SKC
I have a mk1 & mk2 leon that I need to program keys for as I only have 1
This is the one I got and it worked for me....although I got stuck when it came to programming!
http://www.ebay.co.uk/itm/USB-VAG-O...t=Motors_Automotive_Tools&hash=item3a79c59081
What problems did you encounter and did you get it sorted in the end?
I've just seen a v5.5 http://www.resettools.com/vag_can_commander_5.5_with_pinreader_3.9_beta
Thing is it doesnt mention mk1 leon, which I could do with as well
Well I was swapping over the whole cluster so that's were I struggled...went to Midlands VW who did it all for me of £50 but they confirmed that the Pin code I got was the same as the one they obtained.
As for using it on an MK1...no idea to be honest.
