No I had a guy do them for me. Did some tinting myself a few years back though..You tint them yourself?
Yesterday I fitted a new boot lamp, a new stud for the parcel shelf string, and a new high level brake light. Looked a little too bright and red to me, so guess what? I gave it a few licks of tint spray!
Was a bit of a pain to redo, as all three of the bolts for the spoiler had came loose, and I also lost the one bolt for the light. I got it done, but by the time the battle was over the tint was messed up, so have to redo that one.
The orange heat threads don't look so good though..
Also started work with footwell lighting..!
Oh, and ordered a special LED conversion for the interior..
EDIT: And I've ordered some 20mm DRA spacers for the rear...!!!![]()
No I thought that DRS/DRM/DRA was the type of spacer..?! As in DRA were the spacer bolts to the hub and the rim to the spacer..? I ended up with SCC, bought from parts&retards in norway, set me back about £130, but saves me the hazzle of import taxes and shipping etc.DRA so means that you Ordered H&R ?and the car looks so stealth
Nice work
Like this MK1!
What's next for the car?
One thing is a layer of tint obviously..!You're propably right H&R just is only I know that use that DRA, DRM marking.
What kind of plans with headlights??
erm.. just drove it in the dark. Might cut down to half the leds, jesus what an glow! reflections everywhere! Also adding an switch to the circuit!
im going with 3000k to match in with the wheels
