Ok so there are like 400000 posts about this, however I'm still unsure.
I have come across this pic on a different thread:
Which is fine and makes perfect sense, however. Where do I put the axle stands? If I put them in the same spots as shown above, where do I jack the car up from?
I've heard of people using the subframe bolt to jack the car up with, where is that located on the above pic?
I've also seen this photo on a different thread (hope he doesn't mind me using the photo)
But again where do I jack up the car on there if the axle stands are in the points I would normally use?
If you hold a car up on the wishbones chances are you're going to bend the wishbones. They're not load bearing.
