Raees Active Member Jun 26, 2012 61 0 Sep 8, 2012 #41 Had all new injectors done on seat recall. If is was seal on turbo or engine. Would it use/burn noticeable amount of engine oil?
WeeG Active Member Nov 5, 2008 3,297 4 Largs , Ayrshire Sep 8, 2012 #42 Raees said: Had all new injectors done on seat recall. If is was seal on turbo or engine. Would it use/burn noticeable amount of engine oil? Click to expand... yes
Raees Active Member Jun 26, 2012 61 0 Sep 9, 2012 #44 with no real oil usage occuring. where do you think it should start..i.e diagnose, replace turbo, any suggestions welcome?
Raees Active Member Jun 26, 2012 61 0 Sep 9, 2012 #46 No. But the water bottle sensor needs replacing as it beeps.
Raees Active Member Jun 26, 2012 61 0 Sep 10, 2012 #47 Just a thought. Not used car over the weekend and was bad start this morning. Wondering would bad glow plugs cause excessive smoke?
Raees Active Member Jun 26, 2012 61 0 Sep 10, 2012 #48 hi guys really scratching my head...could any of these be the cause of bluish smoke? faulty coolant sensor as mine beeps, OR glow plugs...took longer to start this morning as it wasn't driven over the weekend. all help appreciated.
Alzak Active Member Aug 10, 2010 663 3 Sep 10, 2012 #49 Why You don't get Your car properly diagnosed on vag-com ??
Raees Active Member Jun 26, 2012 61 0 Sep 10, 2012 #50 Is vag com VW diagnostic? no faults come up on this as i've had it plugged in Last edited: Sep 10, 2012
