Barn's Project....returning to a leon.
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
This is next on my list to do, keep up the good work mate :thumbup:
cupra-barn
It's all about stealth!
Aug 4, 2010
2,105
Worcester
Some logs from tonight when we had a quick blast and managed to break the elusive 180g/s
Code:
	Group A:	'003				Group B:	'020				Group C:	'004
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition		Engine Speed	Voltage Supply	Coolant	Intake Air
	TIME			Angle Sensor 1	Timing Angle	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME			Temperature	Temperature
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	 V	°C	°C
	0.4	2400	62.19	99.6	15.8	0.81	0	0	0	0	0.01	2360	13.72	48	24
	1.71	2720	93.75	100	9	2.11	0	0	0	0	1.21	2600	13.72	48	23
	2.93	3120	106.33	100	11.3	3.42	0	0	0	0	2.51	2960	13.65	48	21
	4.22	3520	133	100	12.8	4.73	1.5	0	0	0	3.82	3400	13.44	48	20
	5.53	3960	144.06	100	14.3	5.93	0.8	1.5	0	0	5.13	3840	13.72	48	20
	6.73	4320	152.53	99.2	14.3	7.15	0	0.8	0	1.5	6.33	4200	13.58	48	21
	8.04	4680	161.36	99.6	15.8	8.56	0	0	0	0.8	7.64	4560	13.51	49	21
	9.45	5000	169.81	100	16.5	9.96	0	0	0	0	9.05	4920	13.58	49	22
	10.76	5320	175.69	100	16.5	11.28	0	0.8	0	0	10.36	5240	13.65	48	23
	12.08	5600	180.11	100	16.5	12.59	0	0	0	0	11.67	5520	13.51	49	24
	13.39	5800	180.39	100	15.8	13.79	0	0	0	0	12.97	5760	13.72	48	24
Cheers for putting that up :) And yes, FINALLY broke the 180 g/s. Thats made my weekend!!!!
Cheers buddy, nice to have a little injection of enthusiasm from others[B)]
Yours is looking pretty smart to bud. ;)
cupra-barn
Aug 4, 2010
2,105
Worcester
No mate still in sunny Spain. :lol:
You lucky sod, didn't think you were due back yet, just can't stay away from us :) hope the cars performing well over there.
This evening has seen the rubber of the bushes removed, with some gentle persuasion and heat the just slipped out, no hassle and no smoke :)
And the other side
I'll cut the sleeves out tomorrow and then set to work on the subframe.
cupra-barn
Aug 4, 2010
2,105
Worcester
I've managed to squeeze an hour this afternoon to do a bit more.
Got the bush casings out of both arms so they're ready for some purple stuff :)
Then had to cut the ball joints off as the bolts were rounded off, not having an angle grinder these were done the old fashioned way, with a hacksaw.
Thankfully that's now done so onwards to the next bit. I think next will be stripping the subframe apart, rebushing the subframe and the steering rack as well as replacing the bushes on the ARB.
Lots to get done and it's so close now I'm getting excited!
On a down note I had a warning light come on today, it's the wear indicator for the pads, but if memory serves me correct I've not got it connected so fingers crossed its just a dodgey solder and won't cost anything to sort :)
cupra-barn
Aug 4, 2010
2,105
Worcester
Cars come a long way since i was last on here mate, nice job :)
Yeah changing all the time mate, still got the love so still doing stuff lol
A small update
With everything soon to be changed on the handling front I felt another 'unrelated' mod was required. So after 'sweet talking' the misses I ordered a nomad double gauge pillar.
I missed delivery this morning so went to collect it this afternoon. The lady carried it out the warehouse, a big box plastered in fragile stickers. You all know what's coming next, damage to the box was clearly visible so I asked to check the contents before signing for the goods. This is what I found.............
Disappointed to say the least, I know it was the last one nomad had in the factory so I'm hoping they can sort me out another.
:( sad times :(
cupra-barn
Aug 4, 2010
2,105
Worcester
Got a few more bits sorted over the last couple of days.
I found the plastic trim that goes in front of the inlet manifold, I lost it months ago.
My twin nomad arrived, thankfully intact this time.
I then spent all evening at Tims work pressing bushes and bearings.
Tim in his true photographic style.
We got all the bushes done, both bearings out and one back in, I then ran out of time with the misses not being to happy so had to run home!
Cheers Tim :)
cupra-barn
Aug 4, 2010
2,105
Worcester
Looking good mate.
Looks very good mate
Cheers guys.
As a few of you are aware I'm having issues with the car revving at the moment. Seems to continue revving when you change gear and is idling high. :(
Took the TB off and gave it a bloody good clean.
As you can see, it needed it!
Also noticed this.
So replaced the pipe with one I had in the shed
I also fitted my nomad twin pillar. This is my old vs new
A lot better visability with this one when cornering compared to the old unit. Really happy with it, just need to get my second gauge now lol :whistle:
cupra-barn
Aug 4, 2010
2,105
Worcester
I have an oil temp or pressure gauge kicking around in the garage some where, its the same as mine brand new never been fitted. ;) Also selling my center vent gauge set up inc gauges if your interested.
Picking a second matching gauge up this afternoon mate, paid £15 brand new. I do however need a clutch position switch if you just happen to have one of them. I'm currently awaiting a reply from our local S3 breakers to see if he still has one lol
The revving issue is driving me to the point of destruction now!
