goob2000
Hey guys, got a whining noise doing my nut in (not the missus for once - actually wish it was!!
) on my 05 Leon TDI FR done about 60k..
basically it starts only while driving 40mph + and picks up in pitch the faster I go. It's independent of whether the car is in gear or neutral (sort of sounds like a washing machine), it gets higher pitched the faster I go, and lower pitched when it slows down..
Suspected wheel bearings, but after jacking it up there was no play in any of the wheels doing the 12-6, 3-9 tests, and while driving tried turning side to side to see if it disappeared, with no conclusive outcome. No real wheel type bearing 'grumbling' sounds either...
Did not seem to be a stuck caliper either, the wheels spin reasonably freely. THought about the tyres (P6000's) which are as a bit worn but no feathering or flat spots on them, and noise does not change on different road surfaces. Its just been for an MOT, and they did not flag anything either.
Going to check the driveshaft for play on my day off, but other than that I'm stumped. Could this be gearbox related (even though the car drives perfectly despite this) or something like a pinion bearing???? Would this still complain if the car is coasting out of gear at 50mph? Seems to be getting slightly worse each day (although I'm probably paranoid).
Any ideas?????? Would be appreciated!! Need to really book it into the garage - but I need to pinpoint it down a bit, as it's hard to place exactly where its coming from, most likely front but its hard to tell. Makes it worse I meant to be doing a 400 mile road trip this weekend!
