This is all on one side, the other side still works fine?
Have you tried swapping the fuses over to see if the other side fails.
The sidelight, indicator and main beam are all fine its just the dipped thats not. Iv just swapped fuses and it still the same. Im wondering if its the bulb holder maybe?
Yeah check all connections mines not standard with the angel eyes so can't help with a pic.
Not got a multimeter?
tried the working dip bulb in the non working side?
Thats alright mate. Iv tried 3 different bulbs and nothing. Ill try and get hold of a multimeter tomorrow and check the connection to the fuse holder and then at the fuse box, if no luck then im screwed :(
Finally solved it. Dont ask how but i disconnected the battery again for a long time and put it back and it worked fine. Another mystery solved ;)
