true, happy with the set up for now, I'm sure ill be bored in a few month and change again:D
That's exactly right Invincible!!! You can always change, and either way, both colors look astonishing mate. So damn nice! My next suggestion in terms of colors would be.. black matt with a red hint.
Something like this:
ebay.com/itm/Audi-TTRS-19-5-Arm-Rotor-Wheels-Black-And-Red-Matte-/221159906737?_trksid=p2047675.m1850&_trkparms=aid%3D222001%26algo%3DSIC.CURRENT%26ao%3D1%26asc%3D11%26meid%3D3942319434499471920%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D221143401880%26
It will be sick! Probably the sickest set up ever!!! :3rd: and I will have to come see it personally in Dubai! haha
the problem with matt black is trying to keep it clean! a reason why i would never go for that color!
whenever you come plan a Dubai trip, let me know :D
Hi there do you know how these supercopa wheels sit on the fl cr fr leons, as in do they stick out anymore? as im looking at buying one in the future and I should be able to get hold of a set of these wheels for it, and with 225/40 tyres will be perfect.
Do you have any problems with the loewring springs fitted when cornering.
LOOKS ACE! :)
LOOKS ACE! :)
Hi,
These will stick out much more than the stock 18's as the offset is more aggressive, its ET35 while stock is 52, and this is 0.5" wider so its 8j instead of the stock 7.5j.
Rubbing all depends on what kind of springs you will be running and how low your planning to go, most likely on lower springs there will be a bit of rubbing at front and back if the car is loaded.. I've had to roll the front fenders a little bit with mine when I went for the Eibach Pro Street S coilovers as they're a little soft..
Stunning car mate.
What exhaust is that, those tail pipes look huge and fit the rear perfectly.
Thanks, This is the BCS Sports cat-back, Really love the product and it sounds amazing.
Got it lowered a little more on coilovers now, also had to opt for lower profile tires and installed the Triple R front lip..
Hi,
What do you think the car would be like with H&R springs fitted with 225/40 R18 tyres on these rims?
Not really interested in having the arches rolled and if there’s chance of rubbing it’s a no go for me I would rather have practicality over looks... :)
Obviously I don’t have the car yet just Gathering Ideas at the moment.
Ermmm those headlights are gorgous! Why do they look so much better than the usual 3rd party ones? They look soooo OEM!
Because, these are the quality ones! I assume so, cause mine looks exactly the same daystyle SE13L27S.. right Invicible? and I believe these are made in germany..:)
I would say you shouldnt go for them! with the H&R springs your are most likely to get some rubbing, stick to ET45 and 8J to be on the safe side and avoid headache.
:-o looks smoking hot...:clap:
Yea, Those are German made
Freakin sweet car
