OBD II Wireless Devices and Apps
derelyth
295
Portsmouth
Haha, everyday is a school day.
I agree it does suck. I've been trying to retrofit one. Trying being the operative word.
Aye, I think I came across a thread of yours earlier on VAGOC? Surprised at how much trouble you're having for just one sensor! Makes me wonder how much Seat would charge to fit it and whether it'd make it worth it considering the time you may spend trying to DIY!
Cupra R
2,217
UK.
Visit site
The trouble is with the coding. It's not an easy thing to get done, there are ways to do it but I am still searching for alternative ways lol.
It's not something Seat can code in either (well not on my pre facelift anyhow)
Cupra R
2,217
UK.
Visit site
Also, IF you have the sensor installed it is very easy to spot.
So, just take a look for it. You never know you might just get lucky lol.
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
just been out giving it a testing..
BraddersThe3rd
102
Sorry to bring up an old thread. But I'v just got myself a kindle Fire HD, had a look at the apps and I can get Dash command.. is it worth the £31? Also do the wifi apadtors work with any platform? eg iphone/ipad/android etc
Been looking into this as I would like to get some gauges but dont want to haev to cut or drill holes in my dash etc
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
Another vote for DashCommand here.
Got a cheap wireless device off eBay and works fine. Also used it on my laptop with some freeware tool so the wifi adapter should work on kindle as well
shnazzle
Sep 9, 2011
3,480
Northumberland
Cheers Shnazzle. So its worth the £31?
I would say so. In the worst case, you can get the iPhone app if kindle doesn't play nice.
Have a search on here for the settings. There was another similar post where I put all the settings for a pre-FL TFSI FR.
Aok82
155
Finland, Uudenmaanlääni
I did buy the OBD Bt reader from Dealextreme. They had 2 models similar.
http://dx.com/p/obdii-bluetooth-car-diagnostic-cable-black-blue-orange-dc-12v-41925
I bought the more expensive one because I thought the can bus support would give something more to see.
There is the cheaper similar interpreter only 18$ and it gives all the same data.
I use it with my Nokia E7-00 and OBDdoctor software.
It does not show vacuum or boost for me. I think the depends a lot what software one uses.
I think Android torque app is the best but I cant test it because I dont have anything with android.
How ever the Interpreter works fine and is always attached in my OBD2 port. does not drain battery and connects fast.
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Totally forgot to report in myself.
Got my WiFi reader off hpoolsteve and downloaded DashCommand for iPhone.
Took a while to get it to connect, but the trick ended up being:
1) Plug into car and run engine (doesn't seem to work without engine running for me)
2) Connect to the device on WiFi.
3) Set a static IP address in the iPhone WiFi settings
4) In DashCommand: interface type=ELM, data port = AUTO.
5) Enter your car under Vehicle Manager and add settings:
The diagnostics is simple but gets the job done. I read codes and cleared them successfully. It gets descriptions for the codes if it can find them.
Delays are defiitely there. About 0.5 seconds. So it's not quite real-time, but good enough.
The Race Track mode is quite funny. See where you accelerate, brake and keep level.
Data logger is quite good and you can play it back later as well.
Skid pad is useless.
Dashboards other than the one that comes with Dashboard load pretty slow, and some are better than others.
How did you find all of this sort of info? Trying to get it for a Mk1 LCR but can't seem to get it anywhere :( Dashcommand doesn't seem to be able to calculate things like power and torque accurately without the advanced settings filled in
shnazzle
Sep 9, 2011
3,480
Northumberland
Gathered a good bit by googling all over the place, this forum, and the actual DashCommand manual. Don't remember where I found it, I guess on their site. It tells you what each parameter is and what good values are.
Took a lot of googling to fill it all out.
Also trial and error once it was up. Particularly for the speedo ratio
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Cheers mate, guess the search continues for these values :)
eltawater
Full and wholesome member
May 1, 2008
322
55
A word of warning to those with Android devices. The Wifi adapter only works if you've got root access to your phone, as Google helpfully removed the ability to connect to Ad-hoc wifi connections in the later versions of Android.
Annoyingly this means I've got to keep my cyanogenmod enhanced old phone handy whereas my daily handset with ICS doesn't connect at all to the Wifi adapter.
