Front anti roll bar bushes
Sep 10, 2011
1,479
cheshire
I have had this annoying dull knocking sound on my 2007 fr and wondering are these likley to fail? If not could it be the wishbone bushes?
greyfloppyhat
Senior Member
Jun 14, 2011
673
Dublin/Belfast
I'd get to an open car park and see if it does it while turning sharply left or right into a circle. Either gonna be drop links, arb bushes, or loose sub frame bolts if it does it
greyfloppyhat
Senior Member
Jun 14, 2011
673
Dublin/Belfast
If it doesn't do it when turning its drop links as turning the wheel will take up any slag. If it still does it when turning then anti roll bar bushing or sub frame. If you push the car down at the wings and you can't replicate the noise it won't be top mounts. If it's just making the noise on one side it could also be ball joint or wish bone bushing. You'd expert the alignment to be slightly out if it's either of these, so that's a good indicator. Drop links can go quite quickly if not installed correctly or are shite quality ones. I've seen them go in less than 5000 miles in rare cases
