Just a quick question about the centre fans with climate control.
I think the centre fans are not working entirely correctly on my car.
When I press auto the fans in the car start.
I can feel hot air blowing out of the side vents.
But the air coming out of the central vents doesn't seem to be blowing out at the same speed/pressure. But I can still feel warm air around the vent.
If I select the Central Air Distribution button I can feel hot air blowing out of both the side and central vents.
Is it normal that the central fans/vents don't always blow air at the same speed/pressure as the side fans/vents?
The central vent unit has been moved a few times in order to remove the dash.
Wondering if a wire or something might be damaged.
