You need to use 19mm hose as this is the size of all the outlets on the engine
Sent from my iPhone
Thanks for that Ricky, I will have to get a couple of reducers then... how about (dont flame me guys) the pcv being done away with and just have those crank case little breather filters you see see on some engines? Block the tip, brake boost etc or will the engine fault on no pcv hockey puck? Just an idea, might have missed something!
Sent from my Nexus 7 using Tapatalk 2
You dont need reducers just use the 15mm hose that comes with the catch can as a sleeve on the can fittings
Sent from my iPhone
Is it a serious problem having 15mm in and outlets instead of 19mm. Fitted my toyosport one today and now iv read this im a bit confused :confused: any help will be appreciated
Does anybody know what thread size the barbs are on the toyosports catch tanks?
Thank you for your reply, but i mean 'thread size'. Think ive found a way around it by using 14mm to 19mm adapters.
Had a scan thru this thread. My pipes are getting pretty rank with oil and the one off my charge pipe is discoulered I recon its down to the oil in the pipes.
So fitting a catch can and see of it helps solve this. Just gonna get the ones off eBay, a couple meters of 19mm hoses, T-piece joiner and clips. Anyone else add anything else??
Do the eBay Toyo ones come with de-airiation trays in them? Or are they just empty cans?
