I've looked into fitting a shark fin but all of the reports of bad reception afterwards have put me off to date..
The standard Seat antenna would always out perform a shark fin as the golden rule of antennas is the bigger (longer) the better! (the minimum ideal length for FM reception is around 75cm) However shark fins are fitted to VW's and Skoda's and I haven't seen threads full of owners complaining of poor FM reception. The head units are common across the vag range so unless the reception gain is coded differently for Seat the performance from a genuine vag shark fin fitted to a Leon should be the same as a golf or say skoda superb... But as I said above not quite as good as the standard antenna due to its size advantage.
I should also add that as with most all modern car antennas both the standard Seat antenna and vag shark fin antenna have signal amplifiers built in to help compensate for not being the ideal length /shape.
Found your thread Andy and had a read, any idea what the radio signal test figures equate to? Now tempted to go for the same antenna you went with, looks almost identical to the ones fitted to our skoda pool cars..
I'm not sure what the figures are actually based on! I'm not sure my rns310 unit has the same test mode as the old CD player unless anyone can tell me different then I can post up my results for certain stations for people to compare too
I have been after a aerial my-self but i got told a S2000 one fitted? but i've found this one i am thinking of getting as its a little smaller but is shark fin.
I've got a 310 fitted in mine but I guess we'd need to be parked next to each other to do a like for like on a specific station..
The test value is probably an arbitrary figure with just a pass/fail value on the end of line test.. Just wanted to know if it was stated in db's or similar.. A drop or increase by 3db would be noticed by most people.
Could you just confirm the antenna you went with was plug and play with your 10 plate mk2
