Yeah took the piss getting it off! Tiny turns with the spanner.
I was only going 1.9 with some 83mm pistons but this 2.0TSFI crank out of a 2012 S3 came up from a mate that i couldnt refuse haha. Havent deicded on engine spec 100% tbh once my Ring trip and my holiday is out the way ill set my wish list in stone.
What you planning? I brought and a spare engine rather than taking mine off the road so i didnt get bored and break the car half way through the build.
You do with the engine out? And get the spanner from underneath?
Yeah i'm still undecided on the total plans of what im going to do. I doubt the car will get garaged but an engine will be built for it. Not sure on specs or anything yet as its a while away.
Does the S3 crank fit then? Whats the benefits?
Yeah your best to build it all up then fit it. Which you probably plan on doing anyway.
Just finished reading your thread mate, top work! defo have the same attitude to it as me in that everything must be clean and no expenses spared!
Will likely pick your brains on a few bits
Yeah fits in just gotta change the oil pump drive
Cheapest way of stroking the engine to 2 litre![]()
Hmm okay, i'll keep that in mind mateThanks!
have you started to clean those pistons if not i would probably look into why the last piston has more carbon deposits than the rest just in case it is something sinister.
Looking good mate gona be the nice's mk3 on here imo
Looking good mate, plugs were only 2 months old done less than 1k probably,may aswell get some use out of them![]()
