You checked compression?
Right, tonight I have checked osver coil sticks and plugs, as it says cylinder 2 i swapped the coil stick from 2 to 1 and tried up the road...still missfire on cylinder 2, so i swapped the plug from 1 to 2 (so basically both the plug and coil stick from 2 is in cylinder 1) and still says cylinder 2 missfire, leaves me with either an injector thats gone down or a air leak. Smoke test being done at the weekend. But done all this to see what else comes up.
Sent from my GT-I9300 using Tapatalk 2
Could be degrading wires to coilpack 2, not difficult to check for corrosion or oxidation on the wires beneath the insulation.
And of course could be other things lol I always love diagnostics!
Sent from my iPad Mini using Tapatalk HD
good find.. Now, I would be thinking why did the cat overheat to the extent it did that?
Fuel pressure and lean running springs to mind..
I would be checking afr's under boost are in the 12's if this were mine
sorry i read on after that. that cat looks extremely melted :/!!
