shep0706
243
Darlington
Looking to fit a boost gauge to my FR tdi I've searched around but haven't found a definitive answer where to tap into the intercooler piping and how ??? Any help would be appreciated !!
Shep.
Just read through your RR nice car ! When you mounted the gauge in the vent how did you cut the hole for the gauge ? also do you have a connector that stops the buzz ?
Much appreciated
cheers matey
I used a dremel to cut the hole out for the gauge ..then plugged the airvent hole behind..
not sure what you meen by a buzz?
that's a bleed screw..and I think they are like an m5 thread..so hard to get a nut for..
for the sake of a few quid more buy the proper thing mate..or you'll have a boost leak
Just realised the hose fitting is inserted through the pipe looks like a good piece of kit ! Can't wait for payday !!!
Just realised the hose fitting is inserted through the inside of the pipe looks like a good piece of kit ! Can't wait for payday !!!
yeh mate..its well worth it..took me all of 5 min to fit..and works great
http://item.mobileweb.ebay.co.uk/viewitem?itemId=370797714388&index=0&nav=SEARCH&nid=67429236322 stops about 90% of the buzz, I might buy another just to eliminate it all.
Sent from my iPhone
got one of those coming as we speak,so will report back if it does anything.
I didnt use a drill..i used a Phillips screwdriver to puncture a hole in as I didn't want a drill ripping the silicone apart....and because its flexable you can push the adapter through the hole and get a nice snug fit
