benito
30
israel
Hello everyone.
I'm from Israel and I wanted to share with you in a project I did to my car.
REVO Stage 2 Plus. 374 HP.
1.APR intercooler
2.RS4 Fuel return valve
3.AUTOTECH Fuel Pump Upgrade
4.INTAKE REVO K04
5.Neuspeed HI-FLO K04 Turbo Discharge Pipe
6.Turboback MILLTEK
7.Okada Projects Plasma Direct Ignition Coil
8.Snow Perfomance-Stage 2 Boost Cooler
9.VF quickshifter
10.Greddy Profec Electronic Boost Controller
11.FORGE DV
12.Bilstein PSS10 Coil-Over Kit
13.RS3/TTRS LPFP
14.SPRINT BOOSTER
15.Whiteline Anti Lift Kit
16.Quaife LSD differential
Today:
Before:
If it's interesting I'll put pictures of all the stages upgrading done. :)
hi there cant seem to see your pictures... as its very slow can you upload on a faster site like photobucket.com
Hello everyone.
1.APR intercooler
4.INTAKE REVO K04
6.Turboback MILLTEK
9.VF quickshifter
11.FORGE DV
13.RS3/TTRS LPFP
14.SPRINT BOOSTER
Today:
Before:
Looking at the list of mod's if it was my car, i would remove the Forge DV and fit a Rev G or Rev D one.
Your car already has one as there OEM, Not sure which one you will have but if its not a D or G get it swapped out
id presume its oem m8 as ive no paperwork to say its been changed
best way to find out?
Have a look at the part number, the DV is at the front on our engines, if you lean over the engine and read upside down you can read the part number
if it ends D or G
Two days before the vehicle is tested in DYNOPACK, by graph 374HP and 58.5KGM.
Three tests within a few minutes:
if it ends D or G
Question:
I changed DV from picture (original CupraR) for Forge. Your opinion it was bad resolution?
In Forge DV I have green spring and I know that I must change for yellow. With green spring I had 331 hp.
Sent from CiLA iPhone
Tuners here in the UK have tested numerous DV's and claim that the D and G are far superior to aftermarket ones ie the Forge One.
If you look at 99% of build threads for Stage2+ cars they all run Rev D or Rev G ones. Even the APR Stage3/4 Golf R
