nitrogen filled tires
Matty White
61
northamptonshire
Quick question tyres are inflated with nitrogen not sure of the pros and cons but anyway just wondering how i went about trying to inflate them if there low? Do i now need to put nitrogen in them or what? If so where can i get some from?
DavieTDI
Brain dead
Aug 3, 2013
334
29
kilmarnock Scotland
think its just a case of normal air has water droplets along with it and nitrogen does not. sou keep your Tyre pressure longer with nitrogen. i just refiled with air unless a could find some one that did nitrogen
Jul 12, 2013
249
RETFORD
had mine filled for 14 months now and they never seem to need air unless i get a puncture. kwikfit and ats use gas.
mickyp1989
286
They tested it on 5th gear and it made no difference other than they stay inflated for longer
S7UYJ
320
Manchester
Nitrogen is an inert gas so generally is more stable and doesn't react with much., we don't use anything but to inflate aircraft tires.
Main benefits are low oxygen content, meaning less chance of combustion in a blow out( not really issue on cars) and also won't corrode from the inside, again not really a car issue.
Hope that helps and makes sense!
Ps, no danger or negative effects to mixing the 2
S7UYJ
320
Manchester
Even the fact they stay inflated longer is debatable. It's your wheel and valve that makes the seal, and nitrogen is still a gas so if air will escape, so will nitrogen. It's more the degradation that nitrogen copes better with but to notice it in a car tyre, it would take a long time to show it's effects
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
So, do you vacuum out all the regular air from a new tyre before you fill with nitrogen? If not I can't see that you will be much more than the 78% nitrogen that's in air anyway.
Reactions: TazB
S7UYJ
320
Manchester
I don't think there is a way really! If there was a clear advantage for road cars to have nitrogen filled, then there would be a much bigger market in places like halfords etc, but It's a bit like fitting an f1 rear wing, great for f1 cars, still do a bit on road cars but generally not needed!
I know the gtr has nitrogen filled tyres but more of a publicity thing
My opinion, bit of a waste of money and effort, but If you want to give it a try, it's not dangerous to mix or give it a go!
CatB1
535
Manchester
www.freeserve.com
Guess we are in the same industry;)
