Am not sure how you do it but your mapper would help u with that am not quite sure how todo mapping things who will u be useing to map your car once the parts are fitted
It does when normally tuned but once u get to big power levels ie the 300bhp mark it can be done away with on a diesel and use ur map sensor to do the job as well.
It's not something u can do away with untill your at the big number stage then like I said it's not just case of removing it your map needs adjusting so it's not used. Don't don't quite know how it's not needed but the people I used to talk to on hear that where running the big numbers didn't used to have them.
Massage zach225 he is one of the people who is running your sort of power he might be able to help out with what's required abit more bearin in mind he's running big bhp so he's actually done what your wanting to hope this helps
Finally got round to buying some Ferodo pads thanks to badger5 I will be fitting them tomorrow
IBIZA CUPRA TDI 244bhp
Not done an update for a while been spending a lot of time sorting my squealing problems out haha.
I'm looking at custom fitting a GTB2260vklr bearing turbo on my car .
It's quite abit of fabrication work but will be worth it in the end
Didn't even realise you had an RR thread! We will crack this squealing problem, I won't let it beat me! Love what you did with the intercooler, that's exactly what I want to do to mine to make it more noticable!
