Sound actuator location ... help !
turpi
19
Hi,
After some digging around I've managed to unclip it.
Picture 1 is the location of the actuator (under the plastic grill bit) :
http://imgur.com/L6H1GfI
Picture 2 is the location of the actuator itself. If you get a torch on it its marked 'actuator' on the label.
http://imgur.com/ByeARMm
Picture 3 is a close up of the actuator :
http://imgur.com/yWrauCO
What I used :
Large very long flat tippped screwdriver.
torch
2 cable ties
long needle nosed pliers
Step 1 :
Jam the screwdriver through the grill
Use the flat tip of the screwdriver to pull the grey clip on the top of the plug outwards. It is a little stiff but will slide out eventually.
Once the slidy clip slides out the lead going into the actuator can then be unplugged using the same screwdriver. The whole plug then pops out.
Use the pliers and the cable ties to secure the plug to the grill so it doesn't rattle.
Then no more annoying race car noises :)
If for any reason that website takes the pics down inbox me and I'll upload some more.
turpi
19
very good point hadn't thought of that !
Currently working on that, to gain access to the bay inside i'm trying to work out how to take off the trim next to it but not doing so well so far.
