david451
my leon fr 2008 model got its injectors/wiring replaced (recall) in aug 2012 I remember after it, if left for a time it was difficult to start like the fuel had ran back but not all the time, however overall it has been fine.
yesterday it was difficult to start like it was starved of fuel, missing as it started, when I got to my destination I left it for an hour and on return really hard to get going.
Once started it runs fine but on return to my house I turned it off then tried to start it again immediately and again pure bitch to start, missing as it fired up, but once started runs fine.
Called seat, they said to disconnect an injector at a time because if one is faulty it wont start, but did that and unless two are faulty it made no difference.
I can get it going but it has that classic symptom like the fuel has run back but as you know it cant do that because it pressurises the system. filter etc all fine, checked it again just in case anorl freezing today into the bargain. fuel pressure should be fine because it runs great at speed. injector failure seems to be total shut down when running from what I have read, not like what I have.
Any tips to check, do these symptoms ring a bell. Sent off for a code reader cause i'm stuck. Only thing I can think off is camshaft sensor perhaps and that they have upset it when they were in there, anybody tell me where it is or a picture and if they could have moved it or something.
Any advice appreciated folk kind of stuck and grounded at the minute.
