Badger
2,643
7
Newcastle, Staffs
This is a guide for the fusebox layout in all models from 2002 - 2008 (including Cupra and FR)
If there are any errors, then post below and I'll amend the list.
F1 - 15A - Spare (up to November 2005), coolant pump (from November 2005)
F2 - 10A - ABS/ESP
F3 - Nil - Spare
F4 - 5A - Stop light, Clutch Switch
F5 - 5A - Engine management control unit (petrol)
F6 - 5A - RH sidelight
F7 - 5A - LH sidelight
F8 - 5A - Heated Mirrors
F9 - 10A - Oxygen Sensor
F10 - 5A - Audio system
F11 - 5A - Spare (up to May 2005), folding mirrors (from May 2005)
F12 - 5A - Headlight leveling
F13 - 5A - Power Steering, engine management, additional heating
F14 - 10A - Additional heater, engine management
F15 - 10A - Automatic gearbox control unit
F16 - 15A - Heated seats
F17 - 5A - Engine Management
F18 - 10A - Instrument cluster, air conditioning, headlight leveling
F19 - 10A - Reversing lights, heated washer jets
F20 - 10A - Washer pump
F21 - 10A - RH main beam
F22 - 10A - LH main beam
F23 - 5A - Number plate light, side light indicator
F24 - 10A - Rear wiper
F25 - 10A - Engine management
F26 - 10A - Stop light switch, ESP steering angle sensor
F27 - 5A - Instrument cluster, ODB-II port
F28 - 10A - On-board power supply unit, glovebox light, luggage compartment light, interior lights
F29 - 5A - Climate control
F30 - 5A - Rain sensor
F31 - 25A - LH front electric window
F32 - 15A - Spare (up to May 2006), cigar lighter (from May 2006)
F33 - 15A - Alarm
F34 - 15A - Engine management
F35 - 20A - Sunroof
F36 - 25A - Heater blower
F37 - 20A - Headlight washer
F38 - 15A - Front/rear foglights
F39 - 15A - Engine management (petrol)
F40 - 30A - Engine managament (diesel)
F41 - 15A - Fuel gauge
F42 - 15A - Engine management
F43 - 15A - RH dip beam
F44 - 25A - LH rear electric window
F45 - 25A - RH front electric window
F46 - 20A - Front wiper
F47 - 20A - Heated rear window
F48 - 15A - Direction indicators
F49 - 15A - Cigar lighter (up to May 2006), spare (from May 2006)
F50 - 15A - Cetral locking
F51 - 20A - Audio, navigation, telephone
F52 - 20A - Horn
F53 - 15A - LH dip beam
F54 - 25A - RH rear electric window
Battery Fuse Panel (upto November 2005)
F1 - 175A - Alternator / Starter
F2 - 110A - Interior
F3 - 50A - Power assisted steering pump
F4 - 40A - Glow plugs (diesel)
F5 - 40A - Radiator fan
F6 - 40A - ABS
F7 - 25A - ABS
F8 - 30A - Radiator Fan
F9 - 10A - Vacant (up to April 2004), ABS (from May 2004)
F10 - 5A - Onboard supply control unit
F11 - 5A - Radiator fan control unit
F12 - Nil - Spare
F13 - 5A - Automatic gearbox control unit
F14 - Nil - Spare
F15 - Nil - Spare
F16 - Nil - Spare
Battery Fuse Panel (from November 2005)
F3 - 40A - Radiator fan
F4 - 40A - ABS
F5 - 50A - Power assisted steering pump
F6 - 50A - Secondary air pump (engines BJX, BKV, BBU and BLZ), Glow plugs (TDI engines)
F7 - 25A - ABS
F8 - 30A - Radiator fan
F9 - 5A - Radiator fan control unit
F10 - 15A - Onboard supply control unit
F11 - 5A - Onboard supply control unit
F12 - 5A - Diesel direct injection system control unit (engine BMT), Automatic gearbox control unit
Reactions: mjstokes85
What about the one on top of the battery I have a fuse strip blown in there but no idea what it is for as everything still seems to be working and has been since we got the car several months ago.
Badger,
Any idea whether there was a fuse for folding mirrors prior to May 2005? And in fact, do you know anything about retrofitting the folding mirrors?
Brett
Don't think they were available prior to 2005 facelift.
Also would have a clue without looking at ETKA for wiring diagrams and modules etc...
Anyone know what controls the electric mirrors?
My passenger mirror adjusts but not the drivers..?!
It's on a ibiza 6L (mk4 facelift) 2006 reg.
Thanks.
*WON'T QUOTE THE WHOLE THING, THAT WOULD GET ANNOYING
Hi Badger, could you advise where you got this layout? I'm looking for the layout for my car (Seat Ibiza 1.2 TDI 2014), for some bizarre reason it's not in the owner's manual.
My problem is my windscreen washers (not wipers) have stopped responding and when I try to use them I don't hear the pump going, I've read a lot of the time this can mean the fuse has blown instead of damaging the motor (It's only 2 yrs old). I've also read that it should be a 7.5A fuse but I just want to confirm this before I go off buying 57 varieties of fuse.
Here's my fuses but, as I say there's no diagram on the cover or in the manual which is pretty bad.
(Will edit the link as I'm not allowed to post the pic)
i68 DOT tinypic DOT com/t6ffpz.jpg
