I meant that I've enabled cornering like this:
(5) Leuchte12NL LB45-light function B12
(5) Leuchte13NL RB5-light function B13
Then I've set (1) static AFS light-bei Rueckwaertsfahrt to Double Sided and nothing was happenning when putting reverse.
So i had to use this:
select channel (8) Light12NL LB45 light function C12
select channel (8) Light13NL RB5 light function C13
And now fog lamps are working when putting on reverse but all the time - even when low beams are off.
Seems like your adaptation is not working for me, or I am doing something wrong.
Odd, you are correct the:
Will result in fogs lighting on reverse even when headlights are off, though cornering using
Results in fogs working for cornering, when lights are on only.
This works for me when lights are on only:
Maybe your car is different, a link to my
coding is here, you can compare if you like (this is pre changing the double sided code)
https://drive.google.com/file/d/0BxOfluLej5eTZWJMQS0xeEpyMFU/edit?usp=sharing
