Daniel you need to make sure your interior light are the same first they ain't all the same
Sent from my GT-I9505 using Tapatalk
They look good mate, I know its lazy but could you list exactly which bulbs you got an how many of each?
I see you ordered 4 for the front interior light bud....would the remaining one left off fit in your glove box light?![]()
Or is it slightly different? Looking on your list you copied across, seems similar just one less SMD?
Also, just noticed your second link is to 39mm, aren't they for the vanity and not the rear interior light according to the list?
Just trying to get my head round exactly what I require before ordering.
Guys, can you explain me how to open this cable and replace these lamps?
Any instructions / photos are welcomed. I tried to open it but i wasnt sure and did not want to break anything
Also just for these spot of the car which products do i need to get to replace them with LED bulbs?
Last question. I have replace the bulbs of the rear number plate with LED, but they turn off after a few seconds / minutes. anyone knows how to solve this issue?
Thanks for all the tips Toca, i'll do exactly the same as you then and get that extra one fitted in the glove box.
Believe my car is the same/similar to you? I have a 58 plate Cupra K1?
Thanks for clearing that up, should be the same as yours 39mm. Does it say on them? Or did you just measure?
Cheers for the extra few bits regarding the boot light, as i'll be ordering one for there aswell whilst I'm at itAlready got side lights and number plate LED's bought and fitted from HIDs Direct
No probs bud and nice car
It doesn't say on them but would guess it be 39mm for a perfect fit. Prob best to just double check anyway is it only takes 2 mins. I made a mistake on my last car and just bought some led festoons in blue 36mm but they were 39mm bulbs and had to bend the clip to accommodate the size.
I might go for the number plate lights next but wanted to ask if you get any errors showing up as seem to be a number of threads about errors or them not working etc.
I do get the odd bulb warning on my dash and would expect that to be my side LEDs and drl's but a quick turn off and on of the lights clears this, but no biggy and they still working.
So you going the full hog and doing vanity bulbs aswell with your next order?
So did those 39mm one you ordered fit fine in the rear interior? Just as the list says 36mm that's all![]()
What do you mean by 'open this cable'???
How is this opening? How can i open it and replace the bulbs?
Also what bulbs do i need for these place ?
