Hahaha
Do u think I should see what it sounds like with it disconnected???
One lad reckoned you could hear the exhaust/turbo a lot more with it disconnected....I dunno lol
Try it, on a standard one you do hear the exhaust better at higher revs, and that's with the back seats up, so your modded one should be a lot better. you might be able to try it by leaving the bulkhead off, if you don't like it you could reconnect it easy enough then. Do it, you know it makes sense.....
Disconnecting that rattle box was the best thing i have done to my Cupra, if only getting rid of the plastic flat bottom part of the steering wheel was as easy.
I'll have to ask my master mechanic (aka chris) for a hand at some point as I am liable to drop things in the engine bay or just break stuff lol
Get away if I can do it - mental midget that I am- you should do it easy. And I didn't break or lose anything. Only my virginity but that's another story......
I have shaky old nanna hands
I'm ok at snapping bits of plastic off the inside of the engine bay to make the heat shield fit better tho hahah
