Okay mate no problem saves you the hassle,
Well I would only replace the one that's leaked as to be fair the other wine probably won't ever go ,
You have a few options you change the cv joint or you could get a whole drive shaft there not that expensive online to be fair but if your sticking it in a garage just get the one done
I wouldn't worry about a geo to be honest unless its out , your not really touching anything that will affect geo , the three bolts in the bottom arm you remove are fixed in one place with very small movement for adjustment so you wouldn't be changing anything
I would only replace the one that needs doing. That only needs replacing as the boot split and let grit into it. You could get them to check to see if the other boot is starting to crack up a bit if so get that boot replaced.
They said both are leaking but one had a hole in and the other one looks like it just needs resealing! (Cant see anything coming out of that one). This is prob because the ar used to be slammed on coilovers and only recently changed to shocks and springs
Sent from my LG-D802 using Tapatalk
