What experiences have other people had at trying to get a clutch replaced under warranty?
I have a 62 plate (Nov 12) 1.6tdi on 23k miles that has developed a squeak upon changing up gears while accelerating. The SEAT technician has diagnosed it as a shiny clutch plate that is slipping under load.
Now i'm waiting for them to get back to me as to whether the clutch will be replaced however the technician said its unlikely - something I will contest if so![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
I have owned the car from new (1st owner), serviced when required, it has hill assist and stop/start so I have probably used the clutch quite a bit less than in a standard car. The technician said SEAT will always assume you have thrashed the car which I think is a joke.
Car is perfectly driveable and like I say it only squeaks when accelerating and changing up through gears so doesn't "need" a new clutch, but it is rather annoying
Where do you think I will stand and do you think I should go down the "not fit for purpose" route is SEAT don't play ball?
