That be brilliant if you can do that. Just want the gauge to light up when I turn on my lights. Dont want it lit up constantly.To be honest no ,, but where is that connection point that your thinking of tapping into .. I took that panel off on the right hand side of the steering wheel ... And traced cables to the light switch .. I'm currently in derby working when I get bk tomorrow I can take the cover off and take a pic for u
Yes you can get the switch live from that panel ... When u turn the lights on the gauge goes on and off
Sent from my Windows Phone 8X by HTC using Tapatalk
Well i used a switch live , i used my electricians voltage pen and lights up and off with the toggle switch for the lights ... So that would be a switch live ... That's what i used and it worked
You never specified. I now realise you have a mechanical boost gauge, with wiring for lights. My mistake, i should have known that.
Boost gauge lights will only be on when my lights are on IE headlights im talking about ... Why would i want the lights for the boost gauge on during the day .... When your switching the lights on IE when u turn that switch to right ,, the switch live go down to the headlights which is what i have joined into for the LIGHTS on my boost gauge ... They are not permanently fed as they would be continuously on
What is then
Was just off eBay and only has the two wires unlike alot of the threads on here which have 3. Not too fussed if its lit up all the time but would be nice so it only lit up when I turned on my lights. It has a white face so during day its easy to see.What gauge is it you have ? I've recently fitted one with only black and red wires...although my gauge is lit up when ignition is on ( gauge is completely black when not lit up unable to see anything) wired it up nicely and works with dimmer.
