Stopped off at Bill's after work to get some more done...
First job was to helicoil the iffy cam cover fixing.. the offending fixing... (in the most awkward place!!)
....and the offending thread that came out with the bolt!
So covered everything to prevent swarf getting where it shouldn't and drilled the hole ready for the tap
Wanged in a helicoil...
...and then proceeded to put the engine bay back together
Tomorrow I need to sort out the inlet manifold so I can paint it and refit it
After that I need to spanner check the car, bleed the clutch, fill with oil and coolant then top up the gearbox oil
Happy days
<tuffty/>
Happy days
<tuffty/>
.... lucky Bill had one of those fancy new interference pulleys. I wanted one for my build but they don't make them for the TDI crank.
