I'm going tomorrow, well the £7k one is 38 miles, the other is closer to Birmingham which is about 80 miles. So I'm hoping when I see the first I'll just go for that one
Its an independent garage, would you guys recommend doing my own HPI check? Not sure how honest the garage is as I'm not from the area.
And if yes, how does it work, are there a few different providers, whos best/cheapest
Check inside edge of rear tyres for wear, can mean 4 wheel alignment is out, common Leon problem. Bonnet linings go mouldy, again a common problem and the original 'fix' is a bit hit and miss. Good luck!Almost forgot to a ask
Other than the stuff generic to all cars x Amy seat or leon specific issues on the car I should be looking for when inspecting test driving etc, its my first diesel so ill try not to be too shocked at the noise!!
