and the thread was reborn....just found this which can do it £50
http://www.ebay.co.uk/itm/271321328633?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Pretty sure that the switch won't fit in a Leon. The rotary switch in the Golf is much larger and even if you removed the circular shroud at the front of that switch, the centre still won't fit the hole on the Leon light switch module.
have you got pics of it fitted?
how easy is it to do and does it allow use of auto lights?
I have just fitted this to my car you can make the switch fit
Good work, well done
Do you have to modify the actual dash at all? Or just buy a switch housing off ebay and modify it and fit?
Looks really good
last one honest,
is it plug and play or chop and solder?
Just bought one of these units myself. waiting for delivery now.
For the welcome home lights to work, do you need to connect a lead to a trigger source, like the indicator/hazard lighting wiring?
thanks
