k1_cupra
66
Hi guys, wondering if anyone can help me. Retrofitted xenon headlamps into my 2008 Cupra, come to code them in via vagcom and everytime i click onto the long coding helper and switch 'xenon headlights without shutter installed (Bi-Xenon) and then go to code it keeps coming up with the error;
This equipment number is invalid!
Equipment number must be 5-6 digita: 00000-262143
When going onto the recode module page i can see the code '328969' but is in a highlighted grey box so cant be edited.
Anyone shed some light on this for me please as i need the car for work and im kind of stuck if i cant use my headlights.
Aren't Xenons without the shutter standard, (and use a conventional halogen for main) and ones with a shutter bi? :confused:
Post up the results of a full VCDS Auto-Scan and it will show us what control modules you have in your car and how they're currently coded.
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005502089
Coding: 818C0F2F00041000431D00000000000000007F075C400000000000000000
Shop #: WSC 18434 020 328969
VCID: 71EF8E1568565796643-8024
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 020208 022 0601
Coding: 00056208
Shop #: WSC 18434
I tried both of the options in the long coding but neither work
Do you have the single or bi-xenon lights?
Also, can you list all the components you've fitted in the retrofit?
(Posting a full autoscan is also helpful, as was requested...)
Original xenon headlmps
Kufatec looms
Wiring still to be wired to control module for the bi-xenon.
I brought them used and was informed they are bixenons.
Kufatec looms
There's your problem. You need the xenon range controller installed and coded, along with the sensors on the front and rear suspension.
Full auto scan;
Sunday,01,February,2015,18:09:33:65357
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20140905
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1P0 907 115 C HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: SEZ7Z0H3966835
Coding: 0303000318070160
Shop #: WSC 66565 257 00032
VCID: 2B535C7D8AFA7D461EF-807E
No fault code found.
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006792
Shop #: WSC 04941 785 00200
VCID: 73E3841D124A658696F-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D575265B4EE737600B-8078
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Coding: 00056208
Shop #: WSC 18434
7 Faults Found:
01497 - Bulb for Blinkers; Front Right (M7)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
Mileage: 66554 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 11.45 V
OFF
ON
OFF
OFF
OFF
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 94
Mileage: 66554 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.50 V
ON
ON
OFF
OFF
OFF
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 133
Mileage: 66658 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 66554 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.40 V
ON
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 66554 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.40 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 8
Reset counter: 134
Mileage: 66554 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 8
Reset counter: 134
Mileage: 66554 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A03 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP0W24TV
Coding: 0012339
VCID: 3B736C3D7A9AEDC68EF-806E
Subsystem 1 - Serial number: 6333FTS615410338
Subsystem 2 - Serial number: 6343FTS618340208
Subsystem 3 - Serial number: 6353ETS673U9SVNP
Subsystem 4 - Serial number: 6363ETS6JQS9SVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0100
Coding: 0002042
VCID: 78F9B3310B2C06DEA3D-802D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 925 C
Component: KOMBIINSTRUMENT VO3 0424
Coding: 0002401
Shop #: WSC 80093 222 69422
VCID: 2F6B486DBEE20166327-807A
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K08124034B
Coding: E9807F060002020203
VCID: 3461470157C422BE4F5-8061
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0424
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000010579210
Coding: 0000688
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.154 H08 1901
VCID: 36657D0941B830AE711-8063
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F00068F0FE0085F86107C80
VCID: 830354DDC2EAD50606F-80D6
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 04941
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000608179114
Coding: 0000688
VCID: 3C716F217F94EAFE875-8069
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000002757083
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000002762041
Coding: 0000144
2 Faults Found:
00099 - Rear Right Central Locking (Safe) Motor (V164)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 94
Mileage: 66554 km
Time Indication: 0
00931 - Locking Module for Central Locking; Rear Right (F223)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 134
Mileage: 66554 km
Time Indication: 0
End ---------------------------------------------------------------------
Would the range sensors stop me from coding them in to get them to work though?
When i say the wiring needs to be wired to the control unit i mean the extra wire that comes off the kufatec adapters that goes into the comfort unit by drivers trim to enable the bixenon to work when you flash.
At the moment im having problems with getting the headlights to work i aint going to go ahead and install sensors on front/rear suspension unless i know i can get the headlights working
Yep, no xenon controller.
How can you expect the central electrics controller to accept the coding for xenons when you have no xenon controller??
Do you have a part number for the controller that i need to get? And where is it usually situated?
Come back when you've tried using a cable with the latest version of VCDS installed.
If you can't use updated VCDS software because you're using a clone VCDS cable then come back when you've tried with a genuine cable. There are known issues with some cloned cables so putting aside what modules you actually have installed (or what a clone cable / cracked version of VCDS thinks you have), no-one wants to be chasing their tails trying to help when the issue with the actual coding may be caused by the use of a clone cable.
Am having problems with xenon flash, I've wired pin 11 to the cecm and changed settings on vag com to xenon with shutter installed but now I get both xenon and halogen high beam?? I only want xenon high beam so how do I go about this
I will check if theres any software updates for VCDS when i get home
I would like to confirm i am using a genuine cable not a clone.
Thanks for your help, will update you guys once i get home with regards to if i have the latest software version installed.
Check back on my posts I done this without fitting washers and levelling on my old fr but it will fail mot now! I wired pin 11 straight to the h1 high beam feed with will open and close the shutter!! Do the lights flash on off when you start the car?
Where is the h1 high beam feed, I wired pin 11 to the cecm as per instructions but now they both flash??
Sorry I can't remember which pin it was,
I fitted a pin into number 11 and with a volt meter found the High beam feed at the plug and and connected pin 11 to that,
so when when you flash or turn the high beam on it will open the shutter too, on pre 2009 leons the shutter and h1 do both work at the same time
that way you don't need to fit the range control and levelling stuff but it will fail mot now, my current FR has the factory fitted AFS bi xenons so don't need to worry :)
hope this helps
My car is a pre 2009 but my brother retro fitted his years back and only had the xenon flash and not both. Is there any way I can have only xenon flash?
No from the factory they both flash you could disconnect the h1 bulb but you will get bulb warning can only guess he has his wired wrong having both on is better as you get more light with both high beams on??? Just put some night breaker bulbs in if you are worried about the different colours
