exolive
Hello,
I've blocked EGR by plate (part number 038131925) but now I get ECU error "Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected"
I tried fix it by coding ECU and use this page as instruction for access engine electronics.
ross-tech.com\vag-com\cars\tdi.html#Adaptations
but login code doesn't work for my ECU.
I found information that says this login code works but not for all BXE engines.
Could somebody help me and show correct instruction or show login code which works for my ECU?
SEAT Leon 2011 1.9 TDI BXE
ecu 03G906021SC
thanks for answer.
I've figured already that is impossible to do on EDC16 with diagnostic cable, but unfortunately I did remap ECU and this chip tuner do not remove EGR from map.
Now I have REVO STG2 without blocked EGR, I will probably unblock EGR pipe (remove plate).
