Xenon Lights on Ibiza FR Black
devJORD
OBD11 Wizard
Nov 14, 2014
387
Hi All,
For some strange reason, the FR Black doesn't have the option to add the Xenon headlights! So my question is, what's stopping me from buying them from the dealer and replacing the existing lights?
Thanks.
alijay036
112
Hertfordshire
There are a few options that are missing from the Black, to be honest I wouldn't have thought there would be anything stopping you from buying and replacing.
devJORD
OBD11 Wizard
Nov 14, 2014
387
I thought it was just the Xenons that weren't an option... Which I really wanted, but I also wanted the seats, rims, mirrors and grills. ;)
I've done a little research and people are saying that you can't do it because the black edition bumpers don't have the washers... But surely I don't need headlight washers to have Xenons... :confused:
devJORD
OBD11 Wizard
Nov 14, 2014
387
For an MOT you will need washers otherwise it's a fail, I fancied fitting Hids but didn't want to have to remove them for every MOT
Wow! I've just checked the MOT rules and you're right! What a ridiculous rule!
britishsligean
341
Ireland
I thought it was all hids need washers, checked the rules for the Irish mot and it says it needs washers, stabilizers and below a certain kelvin rating
MjrSharpe
Astra VXR
Jun 18, 2012
504
Northern Ireland
The bumper isn't the issue so much as the recesses for the headlight washers. As well as this you would need the cog sensors for the auto levelling function. You would also be buying the xenon headlight unit as a part rather than an upgrade so it would be much more expensive.
devJORD
OBD11 Wizard
Nov 14, 2014
387
I'm not sure why the FR blacks don't have them as optional and considering it's suppose to be a special edition, you would of thought they would be standard.
I might just get some nice bulbs instead. :p
devJORD
OBD11 Wizard
Nov 14, 2014
387
Ok so I've done some digging around and the key is in how the rule is worded. Spoiler alert: You don't need washers!
"Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given"
