TCS Button
ayster
113
Manchester, UK
yeah traction saps the power (or applys the brake, depending on the system) to avoid things like spinning the wheels and esp stops your car from spinning or flipping when doing sharp turns at speed. some pretty cool vids on youtube showing esp on and off and what happens.
Cool, thanks for that :)
Matt280
148
My Cupra 280 is a 64 plate and has the TCS button.
Not sure if this helps but sounds like later cars have it?!?
schofier
78
7
Southampton
So curiosity got the better of me and must confess hadn't really noticed the button before. Quick press enables ESC sport mode. Long press turns ESC off.
thefunkygibbon
Mk3 Leon Cupra 280
Jan 9, 2012
424
maybe those with the button could post a photo showing it so those who havent found/got it can see for reference?
fwiw, mines 64 plate (although i suspect its an earlier build as didnt have the 280 logo) and don't think i have it. although i think i have a light on the middle panel saying about it. don't think its a button tho
Ocularis
492
Northampton
last button on right, top row.
Ocularis
492
Northampton
Prob a MY15 change... just like the MY16 sounds like it might get some more toys.
It is pretty useful when approaching a busy junction or preparing an overtake to be able to switch it off and on again quickly.
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Is there any correlation between dsg & manual cars ? Ours is a 64 plate 5 door manual built around July/August 14. Also washer bottle is on passenger side, no headlamp washers.
Edit : Just checked and build was November 14.:doh: and it has a button
andrewpain
1,852
Meppershall Beds.
time to own up - was trying to get up a snowy hill in my old merc and it just ground to a halt.
then I turned OFF the ESP/TCS system, the drive re-engaged and off I went!
Forgot that it detects wheelspin and takes power away from spinning wheel. Useless when BOTH driving wheels are spinning!
DOH.....
JMAC
652
Can be turned on/off via the infotainment system though, so no real need for a button:
Car > Car Setup: > ESC
Mine is a Dec '13, headlight washers, reservoir on passenger side, no TCS button. There's no real pattern to the bottle side/washers/TCS mystery!
I'm fairly sure my 63 plate 5dr had the button (150 FR).
hallsy67
116
108
Bristol
Well switched TCS off saturday through the screen as i have no button and tried the launch control. Never again lol. The wheelhop i experienced was unbelievable,I thought the drive shafts were about to pop. Get better launches letting the car creep and nailing it to be honest.
Snah
250
Netherlands
What tires you are on?
My Brigdestone's on my 280 are wore down to less than 4 millimiter and wheelhop is a nightmare with these tires regardsless wet or dry.
Will let them refit when they are gone for Michelin Pilot Super Sports or Goodyears F1 Assymetric2 then for sure the wheelhop is gone.
thefunkygibbon
Mk3 Leon Cupra 280
Jan 9, 2012
424
just tried the same this afternoon for the first time. switched ESP off in its various modes and when putting foot down it juddered so badly. manual car and did it when already moving rather than a standing start. is this normal? the car totally wants to go but can't. i'm pretty sucky when it comes to cars and how they work. what is causing this presumable "wheelhopping" ? is there anything i can do to improve this (other than turning ESP back on)
thefunkygibbon
Mk3 Leon Cupra 280
Jan 9, 2012
424
ok. i'm still on the bridgestones i had when i bought the car. have a fair bit of tread on them left. will look into alternatives when it is time. I presume its only the front tyres which I need to worry about replacing to get around this issue?
