TTE420 logs
POPOV
Newbie
Jun 25, 2005
581
Sweden
What degree sparkplugs are you running? I'm having some misfires at higher rev under WOT but that is on the 98 map. Will be trying out the 95 map to see if I'm having the same issues. Have been told that it also could be caused by the return valve, I'm using the RS4 valve at this stage.
Bignod00
2,201
Lincoln/40,000 ft.
Tbh buddy, I'd look at updating the FPRV, at a minimum I'd be looking at running the 155bar version. Do you think these misfires could be being caused by fuel cuts at the top end?
POPOV
Newbie
Jun 25, 2005
581
Sweden
Your are correct , the FPRV would need to be upgraded along the road to get the full potential of the turbo. I know APR has a ~165bar version for the Stage 3 kit that can be purchased as spare but more the 200€ for it.
I'm running the APR LPFP system and IE LPFP internals, will be logging this week to see how the fueling is. The misfires could very well be caused due to the fuel valve. But I have been told that custom tunes are running with similar HW set up as mine and RS4 fuel valve without the misfires.
Will test the 95 map to see how it acts, in the end we need to keep in mind that the APR map never was build for this turbo so issues can be expected.
WeeG
3,407
Largs , Ayrshire
The map needs to be altered as the fact is APR V3.4 will fuel cut at top end I got the 165 mbar regulator apt LPFP and new map
POPOV
Newbie
Jun 25, 2005
581
Sweden
Did you get the APR 3.4 map altered/customized to suite the fueling needs?
Will the APR 3.4 map fuel cut when running on the 95 map also?
What fuel return valve are you running, APR's?
Thanks for all your support WeeG =)
Bignod00
2,201
Lincoln/40,000 ft.
Hope you get to the bottom of this my friend. I'm personally running a TTRS lpfp and the 155bar fprv with no misfires/fuel cut issues.
It'll all be worth it in the end!
POPOV
Newbie
Jun 25, 2005
581
Sweden
I'm confident I'll solve the misfires. Are you running the APR map, 95 or 98 file?
POPOV
Newbie
Jun 25, 2005
581
Sweden
Misfire issue resolved =) . Fitted BKR7EIX instead of BKR8EIX and my issue is gone. The BKR8EIX where new so either they where faulty or my WMI is doing to good of a job keeping the engine cold.
Running on APR 98 map seems to work for me, did 100-200kmh in 8.2s. Outside ambient temperature 14,5C . With some better shifting I'll get below 8.0s.
https://docs.google.com/spreadsheets/d/1W_gvRMAeSjnMDtvGh4-8tf2o5sK1C0_yV5wZRbcK_Lw/edit#gid=72684885
Code:
1P0 907 115 C		2.0l R4/4V TFSI     0020
	Group A:	002				Group B:	031				Group C:	230
		Engine Speed	Engine Load	Injection	Intake Air Mass		Lambda Sensor	Lambda Sensor				Rail Pressure	Rail Pressure	Rail Pressure
	TIME			Timing		TIME	Current Value	Specified Value			TIME	(specified)	(actual)	Difference
Marker	STAMP	/min	%	ms	g/s	STAMP					STAMP	bar	bar	bar
	0.05	1840	15	0	6.08	0.1	1.99	0.96			0.01	49.65	49.65	0
	0.19	1840	15	0	6.06	0.24	1.99	0.96			0.14	49.61	49.61	0
	0.35	1920	30.1	2.29	32.69	0.39	1.99	0.96			0.28	55.19	50.92	4.27
	0.48	1880	66.2	3.31	33.53	0.53	1.16	0.96			0.44	58.65	58.86	-0.21
	0.62	1920	78.2	3.57	36.67	0.67	0.96	0.95			0.58	61.47	62.47	-1
	0.77	1920	85	3.83	38.83	0.81	0.94	0.95			0.72	64.31	65.61	-1.31
	0.93	1960	89.5	3.83	41.56	0.97	0.95	0.95			0.88	67.68	69.45	-1.77
	1.06	2000	92.5	3.83	43.67	1.11	0.97	0.95			1.02	70.75	71.03	-0.28
	1.2	2000	97.7	3.83	46.67	1.25	0.96	0.95			1.16	73.95	74.63	-0.68
	1.34	2080	101.5	4.08	48.86	1.41	0.95	0.95			1.3	77.22	78.79	-1.57
	1.5	2120	106.8	4.08	53.22	1.55	0.94	0.95			1.46	81.07	81.8	-0.73
	1.64	2160	112.8	4.08	57.94	1.69	0.91	0.98			1.6	84.54	84.86	-0.32
	1.78	2200	116.5	4.08	60.67	1.83	0.92	1			1.74	88.13	88.64	-0.51
	1.94	2240	122.6	4.08	64.61	1.98	0.94	1			1.88	91.92	92.09	-0.17
	2.08	2280	129.3	4.08	70	2.13	0.96	1			2.03	96.47	96.12	0.35
	2.22	2360	136.1	4.08	75.06	2.27	0.97	1			2.17	100.63	100.26	0.36
	2.36	2400	142.9	4.08	78.89	2.41	0.98	0.98			2.31	104.92	105.75	-0.84
	2.51	2480	151.1	4.34	86.94	2.57	0.95	0.97			2.47	109.31	108.62	0.68
	2.66	2520	160.2	4.59	94.61	2.71	0.95	0.96			2.61	112.27	113.93	-1.66
	2.8	2560	166.9	4.59	101.06	2.85	0.94	0.95			2.75	113.69	114.19	-0.5
	2.94	2640	174.4	4.84	104.75	3	0.94	0.94			2.89	114.37	115.95	-1.58
	3.1	2720	185	5.1	116.53	3.14	0.91	0.92			3.05	114.72	115.54	-0.82
	3.24	2800	191.7	5.36	125.17	3.28	0.91	0.91			3.19	114.86	115.16	-0.3
	3.38	2880	191.7	5.87	137.14	3.42	0.88	0.89			3.33	114.93	116.14	-1.21
	3.53	2960	191.7	6.12	149.19	3.58	0.88	0.88			3.47	114.96	114.75	0.21
	3.67	3040	191.7	6.63	159.06	3.72	0.85	0.86			3.63	114.98	115.69	-0.72
	3.81	3120	191.7	6.88	164	3.86	0.84	0.84			3.77	114.99	116.3	-1.31
	3.95	3200	191.7	6.88	164.64	4	0.86	0.84			3.91	114.99	114.44	0.54
	4.11	3280	191.7	6.88	164.72	4.16	0.84	0.84			4.06	114.99	116.25	-1.26
	4.25	3360	191.7	6.88	172.67	4.3	0.83	0.84			4.2	114.99	116.27	-1.28
	4.39	3480	191.7	6.88	184.5	4.44	0.83	0.84			4.34	114.99	115.62	-0.63
	4.53	3560	191.7	7.14	189.25	4.6	0.83	0.84			4.49	114.99	116.22	-1.23
	4.69	3640	191.7	7.14	193.25	4.73	0.84	0.84			4.64	114.99	114.24	0.75
	4.83	3720	191.7	7.65	212.17	4.88	0.82	0.84			4.78	114.99	114.03	0.96
	4.97	3840	191.7	7.91	229.75	5.02	0.84	0.84			4.92	114.99	114.31	0.68
	5.13	3920	191.7	8.16	241.94	5.17	0.84	0.84			5.06	114.99	115.73	-0.74
	5.27	4040	191.7	8.42	259.89	5.31	0.84	0.84			5.22	114.99	114.72	0.27
	5.41	4160	191.7	8.67	265	5.45	0.84	0.84			5.36	114.99	113.98	1.01
	5.55	4280	191.7	8.93	277.94	5.6	0.84	0.84			5.51	114.99	113.46	1.53
	5.7	4360	191.7	9.18	285.81	5.75	0.83	0.84			5.66	114.99	116.73	-1.74
	5.85	4520	191.7	9.18	295.31	5.89	0.82	0.84			5.8	114.99	117.27	-2.28
	5.98	4560	191.7	9.18	307.47	6.03	0.82	0.84			5.94	114.99	113.5	1.49
	6.12	4680	191.7	8.93	315.86	6.19	0.84	0.84			6.08	114.99	115.81	-0.82
	6.28	4760	191.7	9.44	318.14	6.33	0.83	0.84			6.24	114.99	116.24	-1.25
	6.42	4920	191.7	9.18	326.17	6.47	0.84	0.82			6.38	114.99	117.03	-2.04
	6.56	4960	191.7	7.91	330.28	6.61	0.95	0.82			6.52	114.99	117.03	-2.04
	6.72	5120	191.7	9.18	336.5	6.77	0.87	0.81			6.66	114.99	115.46	-0.47
	6.86	5200	191.7	9.69	334.75	6.91	0.81	0.81			6.82	114.99	110.59	4.4
	7	5280	191.7	9.69	333.36	7.05	0.8	0.81			6.95	114.99	114.01	0.98
	7.14	5360	191.7	9.18	337.78	7.19	0.8	0.81			7.1	114.99	118.54	-3.55
	7.3	5480	191.7	9.18	340.14	7.34	0.8	0.81			7.25	114.99	119.77	-4.78
	7.44	5560	191.7	8.93	350.19	7.48	0.8	0.81			7.39	114.99	119.14	-4.15
	7.58	5600	191.7	8.93	349.36	7.62	0.83	0.81			7.53	114.99	127.3	-12.31
	7.72	5680	191.7	8.93	356.03	7.78	0.81	0.81			7.67	114.99	120.62	-5.63
	7.88	5760	191.7	8.67	355.36	7.92	0.8	0.81			7.83	114.99	120.35	-5.36
	8.02	5880	191.7	8.67	353.64	8.07	0.8	0.81			7.97	114.99	122.02	-7.03
	8.16	5920	191.7	8.42	351.64	8.21	0.8	0.81			8.11	114.99	121.34	-6.35
	8.32	6000	191.7	8.42	353.06	8.36	0.8	0.81			8.26	114.99	127.36	-12.37
	8.46	6080	191.7	8.16	353.5	8.51	0.8	0.81			8.41	114.99	125.66	-10.67
	8.61	6120	191.7	8.16	359.19	8.66	0.82	0.81			8.56	114.99	122.76	-7.77
	8.75	6200	191.7	8.16	357.31	8.81	0.81	0.81			8.7	114.99	121.88	-6.89
	8.91	6320	191.7	8.16	349.72	8.96	0.8	0.81			8.86	114.99	121.5	-6.51
	9.06	6360	191.7	7.91	355.69	9.11	0.8	0.81			9.01	114.99	121.02	-6.03
	9.2	6400	191.7	7.91	354.86	9.25	0.81	0.81			9.16	114.99	122.93	-7.94
	9.36	6440	191.7	7.91	295.69	9.41	0.77	0.81			9.31	114.99	119.61	-4.62
POPOV
Newbie
Jun 25, 2005
581
Sweden
Dyno before and after TTE420, 47hp and 61Nm increase =)
Difference between the dyno sessions are TTE420, APR LPFP system, 165bar FPRV and new spark plugs.
Both dyno sessions where made with the 98 APR map file, 98 RON fuel and WMI.
Eengine code BWJ, Stock internals, stock inkectors
* APR 3.4 K04 98 map, 98 RON fuel
* Flapper delete
* WMI, DO3 nozzle in throttle body plate (pass TB), DO3 nozzle in throttle pipe after Intercooler
* 3" DP, Catless, 3" cat-back
* HI-FLO Air charge pipe
* HI-FLO Turbo Discharge pipe and outlet adapter
* 165 Bar FPRV
* ITG Intake
* Godspeed intercooler, no AC core
* NGK BK7EIX spark plugs
* APR LPFP system
* TTE420
* IE HPFP
Bignod00
2,201
Lincoln/40,000 ft.
So, the car has been in with the guys at R TECH having the map tweaked after the exhaust being changed.
Here's some of the early results from FB.
440.7bhp and 427.7fl/lb.
Cannot wait to get her back, planning Snetterton 300 on September the 17th, should be a good shakedown.
Bignod00
2,201
Lincoln/40,000 ft.
Cheers guys!:D
Yeah, it'll be very interesting to see how it performs. Maybe G or Popov have had some exposure to this and could comment?
I know G's a maniac!:lol:
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
This the one posted up recently? Turned back to 420hp for what should be a safe setup with less than 1.6bar of boost and some clever mapping to make the power usable? Niki certainly seemed impressed with it! Will be awesome on track i'm sure
