TonyFSC
121
Anyone know how to input personal POI's into the Sat Nav?
I imported National Trust properties into my Tom Tom and want to do the same with the Leon Sat Nav.
Which SD slot would I use, how would I format and put the data on the SD card, etc?
It says in the manual you can input personal POI's, but omits to tell you how.
Tony
I just so happen to have the manual on my desk.
Page 45 (MY16) Importing Personal POI.
Paraphrasing, slap them on an SD card, insert to media system, Menu -> Setup then System Settings and Update Software.
I don't believe anyone has figured this out yet which leads me to believe its maybe not possible. If it was there would have been a few people adding speed camera's ;-)
It's as a result of reading the manual that I asked 'how'?
Copy TomTom file to SD card?
Put into card slot; which slot, 1 or 2?
Any new file format required?
Tony
I think the only stuff you can import are "VCARDS" which are virtual business cards... and then you can only use the info as a destination...
Took your advice, read the manual again, put POI's on SD card, inserted card into slot 2, message said no data on card.
Tony
Can you create a personal poi on the nav system and see what format it saves to on the card?
We seem to be a bit confused here You are right on the 14/15 Sat Nav systems you can only import a address via a Vcard You cannot import a POI
But looking at what's been said they are talking about a My16 Sat Nav which looks to have the ability to import POI and if so you could add speed camera depending on the format
Can somebody confirm that it is the My16 Updated Sat Nav
Im pretty sure you can set poi through the headunit, will have a play later but i have poi for my work address and home address when i go through the my destinations button
