You are literally a font of knowledge mate.
Good info DEAN0, is there anywhere I can get a copy of the learning module for EA288 engine ??That is straight from the VW self learning module for the EA288 engine
Sent from my GT-I9505 using Tapatalk
Downloaded mine from here - []
the curse of being an Engineer I guess.![]()
The EA288 motor has various stages of DPF regeneration :
• Passive regeneration ( when the engine is up to temp and the car is used mostly on a motorway at a steady speed - the user will not normally notice this regeneration)
• Heat-up phase - ( when the engine is cold - the ECU goes in to a pre programmed heat up phase to bring the DPF up to temp quickly - identified by the higher idle after startup )
• Active regeneration ( The ECU measures the back pressure or soot loading of the DPF and goes in to active DPF regeneration mode - normally identified by a raised idle speed even when the engine is at full temperature )
• Regeneration trip by customer ( Customer must go for a drive to force the regeneration to complete if the DPF light comes on in the dashboard )
• Service regeneration ( Forced DPF regeneration by connecting the dealers diagnostic computer when normal regeneration is not possible )
• Mileage regeneration ( as a safety backup - the ecu will perform an active regeneration every 465 miles regardless of the soot loading of the DPF if it has not registered a COMPLETE regeneration cycle in the last 465 miles )
I measured some data using VCDS and got 0.04g/km soot accumulation on a steady drive.
Can you see the DPF temp on VCDS?
I've read elsewhere that in UK motorway driving, even in a lower gear, the DPF doesn't get anywhere near hot enough to do passive regen. It runs around 250C and needs to be at least 350C to passive regen.
It seems from the VW doc linked to that the car does a mileage based regen anyway every 465 miles if it hasn't done an active regen - so sounds like even if it was doing passive regens it would still do the mileage one.
I work on the calibration of DPF systems for a midlands based premium car company and our 2L engine has a 3L capacity DPF and mileage based regen is triggered at 1200km ( 745 miles ). It also sits in passive regen at anything over 75mph so a lot of motorway driving will lead to very few active regens.
I think a oil change every 5k miles might be the way to go, I plan to keep an eye on oil dilution and go from there.
Thanks for that - can I ask a couple of questions:
How do you get yours to go into passive regen when the VW one is a long way off the required temp?
Would you do that just by making sure the oil level doesn't rise, or by analysing the oil?
Yeah you can see pre and post DPF temps and you are right, normal driving it doesnt get close to a passive regen. Needs a lot of load to get to 350degC and even at that temp the passive regen would'nt be very good, needs to be in the 500's for a good soot burn.
