Andy90
210
Hi. I changed my rear interior lights to LED no issues. So today I changed my front interior lights.. Again..no problem they looked great. I had a spare bulb so went to change the glovebox. This then didn't work. So went to place the original back in and all the bulbs went off. Now they won't work at all.
I'm presuming a blown fuse. But I have no fuse maps or knowledge of where the fuse box is?
Any help is appreciated
Theres a fuse box in the drivers side by the light switch. Open the door and you should see the panel you remove. And theres also one under the bonnet by the battery. Not sure which fuse tho buddy sorry!
I'm wanting to change mine to LED, which ones did you get and where from :D
All from eBay. Don't need to be canbus ones. The front requires 3x t10 (501) sidelight bulbs. And rear requires 2x number plate style bulbs. Very cheap on eBay.
Had a good look today and found on out its fuse 24 (counting from right to left) 20amp fuse.
Changed and sorted!!
Although the panel was a bugger to get back on!
