Fitted my new Peron High flow intercooler. This unit is the most recent and has been updated again for optimum flow and cooling :) already noticed an extra 16 g/s flow over the eurojet. Will get her on the dyno shortly.
Here's a couple of pics
That's quite a difference, be good to see if that translates in to HP
Do you run your car on the same Dyno each time? Have you run it on many others?
Should hopefully give a good idea of any gains then.
Was only curious whether your results were consistent across others, we all know how much Dyno numbers can vary
