Received mine today after a few weeks and wasted no time in fitting it, and if I'm honest its not 100% in fitment but it's not bad, problem areas for me was along the top it doesn't quite clip in an I only managed to get 6 out of the 7 screws underneath back in, now for a couple of pics I took
Sent from my C6603 using Tapatalk
Sound bit of advice there mate will definitely try that when I get round to it.Mine is all on and fitting well, I did spray clips with soapy water o and popped in perfectly. so try that when you refit.
It's the original exhaust.Did you fitted the rear diffuser with the original exhaust or is the exhaust also upgraded to bigger tail pipes?
not far off the price of a genuine cupra r optional one now then
