I ordered one of those windscreen sprayer things that there's a sticky for in this section. Hopefully better than the 3 jet.
Have a look at chipex before looking at a conventional touch up kit.+1 along with giving my glass a through cleaning since Motorpoint cleaning standards aren't the same as mine and ordering a paint touch up kit.
Sent from my ONEPLUS A3003 using Tapatalk
I've only replaced the one, I decided to keep the passenger as a jet because it deals better with air flow at high speeds than the spray does. So the pax jet is angled as far as possible to the driver side of the windscreen, while the driver side is a spray for even coverage at lower speeds/medium speeds.I'm such a muppet.... I ordered one. So now I have a sprayer jet on the drivers side and a 3 jet on the passenger. DOH!
Yes mate,i almost cryed when found first stone chip,just after 3months. Hood and bumper has some dirty chips.Not been on in a while! Got my Leon brand new back in February and today she's just clicked over onto 20,000 miles!!! Glad to be rid of the Bridgestones on the front! Killed them by 17K! And the Dunlops currently fitted are far - far superior!
Today shes had a good clean, only to be totally dissapointed by the paint quality! Bonnet must have at least 5 / 6 stone chips - all of which are now milky white in colour and pretty large, noticed a couple on the roof just above the windscreen too!! And don't even get me started about my 'peppered' front bumper!! Bah.
You did well to get 17k from the front Bridgestones. Mine has just turned 12 month old with 7k on and they're nearly scrap. Just ordered 2 x Michelin PS4 from Kwikfit at £103 a corner....
Im affraid what will be at winter. Protective vinyl is very expensive-just for hood over 240euros.
VAG Familia
Manage to install the VWR600 intake today. It was tricky to get the secondary inlet at the bottom to fix rigidly (still not 100% if it is). But my main problem came at the end where the screw holes didn't line up. I forced the holes to line up and had to leave one hole out to because it was quite far out.
Haven't done a test run yet, however the difference will probably be negligible at this stage
