Couple of VCDS Errors
Stewie14
50
Hello All
Ive recently done a scan of my elctronics and its thrown up a couple of errors
08-Auto HVAC -- Status: Not registered 0011,
19-CAN Gateway -- Status: Malfunction 0010 and
56-Radio -- Status: Not registered 0011
see below for full scan
Sunday,29,January,2017,14:43:09:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56
VIN: Mileage:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LL HW: 03G 906 021 LL
Component: R4 2,0L EDC G000SG 9185
Revision: --H02--- Serial number: SEZ7Z0F3506797
Coding: 0050072
Shop #: WSC 66565 257 00032
VCID: 74EDC20917A00E9
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441 785 00200
VCID: 3F875D256E669D1
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
VCID: 356B3F0D5C5A571
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004095075
Coding: 21884F2F00041000001D0000000000000031FF0F5C
VCID: 2B5F19758A1E111
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R5 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PN2AD01
Coding: 0021045
Shop #: WSC 61123 476 96635
VCID: 2F670D65BE066D1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
Component: J0527 056 0101
Coding: 0002042
Shop #: WSC 12345 123 12345
VCID: 7CFDEA293FF0469
Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 923 C
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002401
VCID: 2D5B176DB40A1F1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065278208
Coding: 3D0F012007000203
VCID: 2C5D1A698F10169
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 F HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1118
Revision: 12006001 Serial number: 00000580768512
Coding: 0000560
VCID: 3A712C317544B89
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 59F800CE7F000505C89BAE1004CC
VCID: 79F3F33D30C2731
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 F HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1118
Revision: 12006001 Serial number: 00000046968505
Coding: 0000560
VCID: 3B7F29357A7E811
Address 56: Radio
Cannot be reached
End ---------------------------------------------------------------------
any help with these will be greatly appreciated
Scby555
166
If your can gateway is malfunctioning then you can't trust the other errors, they may be false. Replace your can gateway module first behind the dash, £30 on eBay
Sent from my SM-G903F using Tapatalk
Stewie14
50
Hi
Thanks for your reply do I just search for j533 on eBay then?
