Hi
This is for the FR, but I assume the setup is quite similar.
I can't send pictures or links, but if you add after -forums- in the address bar showthread.php?t=407064, there are good instructions on how the grille is set up.
The front
badge is "clipped" in. There are two longer guiding pins on the back side, and two clips (hooks) on each of the 4 sides around (These need to be pressed towards the middle). The
badge was so tight I actually ended up removing the grille (and that meant the bumper) and pushed the clips in from the back side (since the frame around was also changed).
Instagram - dasilfva, and scroll down a bit to see the result.
The rear
badge was easy to swap with the whole handle. First remove the inner trim. It is clipped from the sides. If I remember correctly there are two bolts holding the trim. The liner is basically the lower half of the trunk liner. There are tree bolts that draws the
badge against a metal "back plate", that keeps the
badge in place. The
badge has a long plastic pin that keeps the metal back plate at it's place before tightening.
(P.S When swapping the boot
badge, one might also want to do a rear wiper removal).
