BASH29
244
East Midlands
Hi all
its been a while since i last owned a seat! bigger family this time round so have decided to try the freetrack!!!
straight away i can see that theres not many fans on here!!!
can anyone help with advising on the best way forward for the following mods....
*most cost effective way to lower the freetrack by 40-70mm - can i use the standard XL springs to reduce height by 40mm???? or potentially 70mm lowering springs designed for altea xl???
*most cost effective way to increase the performance of the front brakes - i did like my brembo's on my cupra R. but there not cheap for the freetrack. what can i utilise from the VW/audi group that will help?? S3 set up?? R32 setup???
looking to complete a stage 1 map to get approx 250BHP. hence the brakes above.
any suggestions would be appreciated.
Octavia scout, yeti. Tiguan, 4 motion golf, A3 quatrro, Q3
Phone some advertisers from out a PVW mag. Shocks and bumpstops as well as springs? rollbars? airride?
Brake donors Audi TT, A4, S4 S6, SQ3, SQ5, Golf TSI-R, Passat R36, Toureag, Porsche boxter, cayenne?
Appreciate the help on the springs, will have a look.
Does anyone know if the altea xl stanard springs would fit the freetrack as this would give me a 40mm drop.
Kev @ Revo bought my Freetrack, it's sat on coilovers with a set of their brakes
It also has Stage 3+ so is fairly quick too now
Thanks appreciate the pic n info, looks nice. Are they 18" or 19" wheels?? Ride height looks good, but I don't want to spend to much on lowering hence looking at just springs or utilising oem altea xl springs. Need to do some more research.
Hi all
I've cupra r fronts on my altea tfsi... I bought it with them already fitted but was told they were off a 2015 cupra r...
They look good, looks like you got them in with the original 17" wheels, bonus. Have you ever thought of lowering?? If so please share!
I have thought about dropping it 30 mil just but have decided not too as it's a family wagon after all so don't want to spoil comfort plus nearly every street in a 100 mile radius from where I live has speed bumps lol
How were you going to go about dropping 30mm, what make springs were you going to use.
Was going to use lowering springs... H&R are meant to be decent... around £170 for a set on Ebay.
I can't find any springs for the freetrack at all! Just finding altea xl 30/40mm drop. That means a total drop off 70/80mm which will not be gentle on the current shocks!
H&R that you found were they specifically for the freetrack???
Reactions: Dani Diaz
No mate they were for the altea... being a sort of off roader and it generally sitting higher because of that lowering it may cause all sorts of problems for you but I really can't say... I'm sure someone here will know though.
At the moment it looks like for a 40mm drop the best option is to use the OEM altea xl springs, will have a better look once the freetrack arrived in the weekend.
