Snowman
306
24
Has anyone measured their 100-200 time with a Cupra?
I would be very interested in the times that people were seeing, both 280, 290 and 300 aswell as tuned ones.
Sorry I can't be of more help, other than pointing out the correct unit of measurement and none of this new fangled 'lets make it easy to add up rubbish' :D as I always drive within the posted speed limits so the fastest I've ever been is 70 mph officer ;) :whistle:
Approximately 9,5 sec depending on wheels (winter/summer), weather etc.
290 DSG ST, Revo stage 1, 382 hp and 465 nm.
DSG/Manual?
What kind of boost are you hitting?
What did you measure the time with?
Ive just done a couple of pulls and im running around 350 hp, DSG and Cupra 290 ST and im in the low 11 region.
Stock Golf R should be around mid 13s, so if you are around 9,5 thats VERY good considering a M5 V10 does it in 8,8s with 506hp.
Golf GTI Clubsport (265hp) should make it around 15s..
DSG/Manual?
I have no clue about the boost it is running, but I can check tonight when I have to go to Germany anyway.
The measurements were done with an app for my phone.
In respect of the M5 (the old V10 version) I have played with one on the highway and he could not pull away from me - neither could I from him..
On another note the fwd 280/290 (and fwd 300) Cupra's is significantly faster from 80/90 km/h up than both the R's and S3's. Both the saved weight and the lower drivetrain loss of the 2wd configuration is contributing to that.
Reactions: LouG
Cupra 280 Revo stage 2, dsg @ 9.31 corrected on vbox but temp was very low
410 HP and 574 NM on dyno.
Trimis de pe al meu SM-G950F folosind Tapatalk
Surely you mean 10.92 microdays?
Hours, minutes and seconds were scrapped by the Timelords millennia ago. :snack:
Well, it isn't.
Vbox is the only true accurate measurement, not a phone app.
Also for under 7 seconds you need 525+ power.
