Hardwired the dash cam in, just need the sticky window mount as the suction one sits a bit too low. Pleased it works when the start/stop kicks in.
Also fixed the drivers door card as it was loose at the top, much happier now as it sits flush and how it should!
First time I have taken the car apart as I only got it last weekend. Pleased at how well it is put together, better than my previous car, a Skoda.
Also removed the silly fake engine noise and made all modes have red door cards. Couldn't get the fogs and headlights to work together though![]()
I'm pre, 63 plate. Looking for fogs to work with main beam if it's possible. I've seen YouTube videos showing it workingok and are you a pre facelift car, is this supposed to put the fogs on when you flash your lights or are you after fogs on all the time with the lights or DRL's
Thanks bud, I'll have a play later when the laptop is charged back upi am obd11 user and the following coding sets the fogs on when you flash lights or have your high beams on
Long flash burst together with the fog lamps
With this change each time you press the burst in the lights of your car, will light while the front fog lights.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte12NL LB45
4 - Sub - Lichtfunktion c 12
5 - Change value to Left high beam
6 - Select - Leuchte12NL LB45
7 - Sub - Dimmwert DC 12
8 - Change value to 100
9 - Select - Leuchte12NL LB45
10 - Sub - D 12 Lichtfunktion
11 - Change value to Lichthupe generell
12 - Select - Leuchte12NL LB45
13 - Sub - Dimming direction DC 12
14 - Change Value to Maximize
15 - Select - Leuchte13NL RB5
16 - Sub - Lichtfunktion c 13
17 - Change value Right high beam
18 - Select - Leuchte13NL RB5
19 - Sub - Dimmwert CD 13
20 - Change value to 100
21 - Select - Leuchte13NL RB5
22 - Sub - D 13 Lichtfunktion
23 - Change value to Lichthupe generell
24 - Select - Leuchte13NL RB5
25 - Sub - Dimming direction CD 13
26 - Change Value to Maximize
as I dont have VCDS I am afraid you will have to check through the menus but it looks like you have some other changes to make as well.
i am obd11 user ...
The more I see it the better it looks.
Is it the Pro version and is it basically the price on their web site of the basic tool + Pro upgrade? Is there a risk of being hit with customs duty or the like?
I took my car to Carttitude in Manchester for a bit of new car protection. They are doing a 2 Stage paint correction and using Gtechniq Crystal Serum Light overcoated with EXO Ultra Durable Hydrophobic Coating. Check them out on Facebook.
How much is that setting you back?
Seat Leon Cupra 290 DSG Black Edition (Alor Blue)
Performance: Racingline OEM+ Stage Two Mapping | Racingline R600 Intake | Racingline Turbo Inlet Pipe | Racingline Turbo Elbow | Racingline Muffler Delete | OEM NGK Audi RS7 Spark Plugs | 034 Motorsport Dogbone Mount | GFB DV+ | Milltek Large Bore Downpipe | Pipewerx Custom Cat Back Exhaust | Forge Turbo Blanket
Interior: Koonlung K1S Dash Cam with BlackVue Power Magic Pro
Exterior: TRC Front Splitter | Foliatec Exhaust Paint Gloss Black
You want the pro version that way you dont have any extra's to pay for as you can code your own changes or save up the free credits to pay for apps.
It does not support Apple and it will be a long time before they do imo
Yes it comes from Lithuania and at this time there is no custom duty to pay (at least I did not have to).
Check out this thread http://www.seatcupra.net/forums/showthread.php?t=432976
and the obd11 forum http://obdeleven.proboards.com/board/45/leon there you can see some of the facelift and non facelift changes.
