Ibiza 2014 Stereo Removal
fat andy
67
Nottingham
Hi all, my 2014 Ibiza doesn't have DAB so was looking to change the head unit. As it looks like a huge palarver to put a double din unit in there I've opted to buy a standard ibiza DAB unit and do a straight swap so it'll still work with the Garmin.
The only problem is I can't get the stereo out and all the youtube guides are for the stereos fitted in up to 2012 models. I've managed to get the surrounding trim off but can't see how it's fastened in, could anybody help me out with this with a quick photo and/or guide?
Thanks in advance
cartmanbdx
99
There are several posts on removing radio you need two
cartmanbdx
99
I changed to double din and it is great! I would recommend doing that, and my pioneer has dab as well
fat andy
67
Nottingham
Cheers for this, are those the only things holding it in then? I was going to get a double din, they do look good but the chopping out of plastic inside the dashboard and the relocating of switches has put me off
cartmanbdx
99
It’s not so bad to do, but yes those are the only 2 things holding radio in on post facelift models
fat andy
67
Nottingham
Thanks, I might go for a double din instead then if it's not too bad, what Pioneer have you got? Did you have any trouble with the button relocation? Do the tyre reset and esp buttons still work ok?
cartmanbdx
99
Everything still works on mine I re pinned everything
netizen
Hi
Can you tell here what model that you have?
Is everything works? Even when the doors open, the unit shows you that one open is open?
I'm in stock radio in my SEAT IBIZA FR 2014, and I want to change to 2din...?
Any android that works fine in this model?
